ttracy
- Messages
- 9
- Reaction score
- 0
- Points
- 0
I replaced our 5 year-old 1/2 HP 5GPM pump this weekend with a Goulds 10GPM 3/4 HP unit and a 44 gal Weltrol 250. I thought I did all my homework to properly size the pump (and more importantly, the new welltrol tank). To give you some history, we built our 4-bedroom, 3-bathroom, 2-story house in 2002 and let the well drillers size the pump, tank, etc. Our well is 180 ft deep, pump set at 160 ft, well produces 8GPM, and no static level (water level is limited to 1 foot below grade by a second pitless adapter that spills a line into the woods). Original pump was 1/2 HP with a 20 gal welltrol tank (202?).
Anyway, my concern is that the new pump only runs for 50 seconds to bring the new tank (44gal Weltrol 250) up to pressure. We used to run the psi at 40/60 but I let some air out of the drained tank and reset the pressure switch to 35/55 psi to try and increase the runtime a bit. We also installed a 10GPM dole valve before the tank (because of our high static water level). Should I be concerned that I oversized the pump (or undersized the tank?) and the pump only takes 50 seconds to fill the tank? I'd hate to have to replace the new pump in 5 years (again).
By the way, drillers didn't even bother to install a torque arrestor (or a dole valve - which I think is required for high static level wells)
