stockwatchn
- Messages
- 10
- Reaction score
- 0
- Points
- 0
A bit new to working with a pressure tank. The old setup was galvanized and very rusty. I removed all the galvanized pipe in the house and went with pex. I'm coming in with 3/4" pex to the Brass tank cross then up to the hot water heater and manifold.
I found this brass tank fittings kit in my hardware store and it looked pretty close to what I wanted. See attached image. Did I plumb this correctly? I had to use some plastic fitting because they didn't have all I needed in brass. Is this ok? Also the kit came with a 1" Check Valve, do I need to install this. Where would it go?
Thanks in advance
SW
Thanks in advance
SW
