kinda new to this and having many troubles.
I have a 27 ft sandpoint well with a 2 foot screen. roughly 4 ft of water in the pipe. I can prime it with a hand pump and then when I run my jet pump I have very little pressure coming from the faucet. If I turn the faucet off the pump will run without ever building up enough pressure in the bladder tank to shut it off. If I let it run like this I end up losing the prime in a matter of 10 min. If I leave the faucet open it will run with little pressure for as long as I want it to? The check valve is working fine as I thought that was the problem and put another new one on.
At the begining of season had the same problem. Got the pump rebuilt with a new impellar, dug up the pipe, put a new point on and check valve. got it working fine. now it has crapped out again.
Could the impellar be gone again. It is an older pump according to the guy that rebuilt it, Should I just buy a new one and if so 1/2 or 3/4 horse.
Does it require a deep well attachment or would a straight jet pump suffice?
please advise as I really have no idea on this thing
thanks
thanks
