Results 1 to 10 of 10
Thread: is it possible to convert back outlet toilet plumbing to down outlet?
Hybrid View
    Default is it possible to convert back outlet toilet plumbing to down outlet?
    hi there!
    I hope my title made sense...
    we are doing a bathroom remodel in our loft - which is in a 1917 building that was renovated in the mid-1990s.
    we had picked out a toilet we liked and then our contractor told us that we need to have a back outlet toilet (not necessarily a wall-mounted one, but back outlet specifically)... and as many of you know, the selections are minimal. we are not interested in a wall mounted toilet at all.
    so my question - is it a huge ordeal to have the plumbing converted so that it can accomodate a regular "down outlet" toilet? our pipes need to be moved anyway as our toilet area is being moved several feet from its current placement - so we already do need to have plumbing work done.
    thanks so much for any input!
    Yakima WA
    Sounds like this is the time to do it since you are going to be redoing the drains anyway. One positive thing is you will have many more choices in toilets. I would urge you to seriously consider the Toto line.
    It's probably a good idea, but it really depends on how much access you have to the drains and how they're layed out how easy or hard it will be.
    If your contractor says you need a wall outlet, I would ask him if it's possible to open up the wall below your unit and the floor to move the piping around.
    If it's only $3000 to move the piping, then it may be a good idea.
    Or, you may want to stay with the wall outlet after all.
    American Standard Yorkville
    Gerber 21-310
    and Kohler makes one.
    Jul 2007
    USA
    Minimal selection?
    Investigate ordering one from Europe, specifically England. They are all like that.
    Careful with the supply line spec though. These will be in milimeters, not inches.
    Dec 2007
    And have to deal with parts locating difficulties til the end of time...
    I don't think so!
