elgato
I just removed an original toilet in a 30 year old house with a slab floor and 3" ABS. The flange is plastic and appears OK and at the correct height. There is about an inch of clearance between the concrete and the ABS which allows the flange to move a bit to either side. Should this gap be filled in or screws installed through the flange to make it more secure?
Thank You
Thank You
