Results 1 to 9 of 9
Thread: PVC - Copper Pipe Joint
    Unhappy PVC - Copper Pipe Joint
    The PVC pipe broke at the joint between the 1" supply line and the primary valve right at the end of the threaded copper pipe. Do I replace the threaded copper end or how do you remove the threaded pvc from the copper?
    Yakima WA
    Is the threaded copper a female adapter? If so, it might quicker and easier just to cut the adapter off, sweat a new one on and not even attempt to remove the broken PVC. To remove it, you'd have to make a couple of cuts in the PVC then pry the pieces out. You'd mess the copper threads up to a certain extent doing this which could make it difficult to get a leak free connection, and you'd not make very good wages saving the cost of a new adapter.
    Red face New Adapter
    The copper fitting is female. So just grab a torch, take it off and add a new one? Any special considerations for solder, gas ??
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Quote Originally Posted by jgalway View Post
    95/5 tin/antimony solder, Oatey No. 95 tinning flux, and a propane torch will work fine.
    Very good cleaning is important.
    Default joint
    Leave the copper alone, and remove the plastic piece from the female adapter. There are several pipe removers that will work.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    You can always melt the remaining PVC and pry it out of the fitting.
    Used the torch to remove the female fitting. It came off easily and so did the PVC which was quite soft. Reattached the fitting. Will be testing the system today. Thanks
    Default pvc
    How did you reconnect the pvc to the copper? Not with another male PVC adapter, I hope.
    DIY Senior Member Mr_Pike's Avatar
    Jun 2007
    Nebraska
    I quit using PVC male adapters a long time ago. If you need to make a connection to female Iron or copper pipe. Cut a Pipe Nipple in half and use a coupling to join half to the PVC. You will have a joint that is twice a strong...
    A PVC male adapter might as well be perforated at the bottom the the threads.
