Results 1 to 6 of 6
Thread: Can't Remove Shower Drain -- Part of Shower Pan? (pics)
    Default Can't Remove Shower Drain -- Part of Shower Pan? (pics)
    Is it possible that the drain was permenantly attached to the shower pan? I had a leak, spent two hours getting out the lead and oakem thinking I could replace with a rubber gasket. Local plumbing supply suggested repacing with PVC and using a rubber PVC to copper coupler. I can't figure out how to remove the old drain.
    Appears to be one piece -- no threads or gaskets... House is 30 years old, unsure of shower.
    Bottom (note joist appears in the way):
    Top:
    Dec 2007
    "Terminate with extreme prejudice!"
    Remember Apocalypse Now?
    That drain is "fixed" to the pan.
    A rubber donut may work.
    Default Options?
    Thanks Terry, that is what I was afraid of. If I can't get the donut to work do I need to look for a 100 year old plumber who still uses lead and oakum?
    DIY Junior Member pbradley_1's Avatar
    Jul 2008
    Colorado
    It looks like you have a wedge-lok (sp?) drain. Thay are still sold. There is a dount gasket that goes between the flange and the pipe. Not sure why something else was in there. I just removed the one from my shower.
    Default drain
    It should be pressed together so if you cut a slit in the lower piece it should open up to allow you to pull the two pieces apart.
