Scubasteve
OK, my old shallow well was putting out 5 gpm with a little air mixed in, while designing my sprinkler system I got greedy and wanted more water so I put a new meyers hj100s 1hp jet pump on it and it didn't get much better, if at all. I pulled the old well pipe out of the ground and it was 38', water at 20-24', and 10' of pvc sand point at the end (pretty well clogged). I jetted a new casing and 1 1/4 x 6' pvc sand point into the same hole to the same depth and removed the casing. Finally primed after filling the pump case and 8' of horizontal pipe about 15 times but only got 1-2 gpm out of it. I'm getting really tired of throwing money at it but I don't know what to do. Do I need to develop it? Drive a new point in a new spot? I can buy a hand pump to develop it but it's nickel & diming me to death so far. (I left out all the B.S. details in between). So...
New pump identical to the old one, new well pipe, new sand point, new brass check valve, all in a location proven to get 5 gpm but I get nothing. What do I do??? Thanks for all the help I got off the site already and any more you can provide. I think it's unconstitutional to PAY $1100 for an irrigation meter so you can PAY a little less for water/sewer, hope it doesn't come to that. Thanks again everyone
Steve
Oh yeah... is it worth it to try to pull the point up a little higher to try to find water?
Steve
