Usually it is the city's responsibility to bring the water to your property and install the meter. Certainly they would insist on doing any street opening and closing. You might have to pay for the meter, but that is arguable in my opinion since you didn't own the property at the time of the theft. After the meter, it is your problem, but I would go with copper although you can use PVC underground from the meter to the house, but not inside. As far as cost, it is hard to determine from afar because of the many variables involved. Certainly copper is very expensive now days, but 39 feet of copper should not bankrupt you. However, labor can be even more than materials. The line from the street to the house in your areas needs to be fairly deep, so unless you have a source of cheap grunt labor, you might look into having it tunneled or contracted to a backhoe operator. Verify what I have said regarding the city's responsibility with the city water department.
