Need to find out what code says about maximum # of elbows in steam lines, spacing of elbows in steam lines, special considerations when putting steam lines in a wall and if I can or should drain the boiler to the waste pipe or drain it more like a water heater. HELP!
Thanks for your help.
PS. I'm installing a MS400E steam shower generator. I've gone through all their instructions, but am doing the install myself. The supply comes from the hot water (per MR. Steam suggestion) and is 1/2" copper. The drain is also 1/2" copper and water coming from the drain will be hot. 4 hours after use of the steam shower, the system autoflushes and the still hot water comes out the drain.
