Originally Posted by
Andy CWS
Are you saying that modern ROs are using pig bladders? Or are you referring to the French scientist that discovered the process in 1748 long before the invention of toilet paper. But of course, all in jest, right? Whew, you had me going there for a moment.
I am not I get your understanding between total production per day and actual storage capacity.
I am not familiar with any modern RO that continuously dribbles to the drain as automatic shut-offs are standard even with the el cheapo models. So the "windshield wiper effect" ceases when the tank is full. The contaminants in the water are given time to rest along side the membrane and a deterioration process can begin. That's why most manufacturers give a maximum one-year warranty on the membrane.
I am not familiar with any home unit that holds 4 gallons. You can purchase upgrades of, say, a 7-gallon tank that can hold four gallons of draw-down water depending on the air pressure you set. Good luck getting that under the sink! [:-}
