View Poll Results: Backstabbing or Screw terminals?
Voters
4. You may not vote on this poll
  • Backstabbing
    0 0%
  • Screw terminals
    4 100.00%
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Backstabbing (push ins) or screw terminals?
    Default Backstabbing (push ins) or screw terminals?
    Which do you like to use? Which one do you think is safer? I prefer screw terminals.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    UL does not have a problem with push-in-terminals, IMO, I've seen just as many bad splices as I have failed back-stab's, so IMO, it all goes back to the installer.
    Nov 2006
    I have never seen screw terminals end up looking like this backstab:
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by leejosepho View Post
    I have, when the installer forgot to actually tighten the screw... the foam probably didn't help matters either.
    Jun 2007
    NY State, USA
    I smell a troll.
    I refuse to get involved in this thread.
    This post made, the first post by a new member, with a totally obscure screen name, and NO profile information, on one of the most contentious electrical issues.
    What's next buddy, you gonna ask if we install receptacles ground up or down???
    How about asking if we pre-twist wires under a wire nut???
    Hey, if I am wrong I apologize. I'm in a crappy sarcastic mood this morning.
    If I am right; so there.
    Petey, I have a sister out law I always thought was really a troll, what does one smell like? Can you verify? She always smells like smoke.
    Or this one?
    Vote now: lol.
    One more smoking troll
    Also, never backstab they are sometimes too short and fall out, always screw.
    Where's the box there? Is it under the melted insulation?
    Default poll
    You say you prefer screw terminals. What is the purpose of the poll? If the majority prefer backstabbing are you going to change your preference. And what about "backstabbed" connections that use a screw clamp to secure the wires?
    Plumber jimbo's Avatar
    Default Putty or silicone??
    This is one of those debates which have no right answer.
    As mentioned, the so-called back-stabbed connections ( not the same as "BACK WIRED") are UL listed ( 14 guage wire only ) devices and perfectly legal. Many of the electricians on the internet poo-poo their use, but a LOT of electricians all over the country continue to install these in new construction for the obvious reasons.
    Just like many plumbers on the internet poo-poo the Plumb_qwik stops with ingtegral corrugated supply.. But a LOT of plumbers around the country continue to install them in new construction for the obvious reasons.
    I think the one summary comment I could make, in both the electrical and plumbing examples, is that you probably will have a difference in life expectancy of the product. There is no code I know of that says everything you install in a new house should last for 25 years. That is a
    "quality of construction" issue which the builder, and buyer, get to weigh in on.
    Jun 2007
    NY State, USA
    Well after looking around a bit I see the OP is just a novice and the question is likely valid. Thing is this has been gone over ad nauseam, just like the other topics I mentioned.
    Let's just say nobody who has been in the field long enough to know better would EVER use "quickwire", "backstab", or whatever you want to call it.
    We've ALL seen WAY too many failures due to this to even consider using them.
    In my own personal opinion I don't think they are reliable even if done correctly. I've seen failures in brand new never lived in homes (modulars) where the wires were perfectly straight and true.
    The connections that use a clamp are good aswell.
    Jun 2007
    North Carolina
    This is a true poll as it was opened for less than an hour.
    That was one short poll.
    Maybe it was the Trolls, I am sorry...I can't help it, I wake up sickening silly & playful.
    Default poll
    Well, it was four to nothing, 100%, so that tells you something.
    Quote Originally Posted by Cookie View Post
    troll? sorry i dont know what that is exactly
    Jun 2007
    North Carolina
    Quote Originally Posted by rgsgww View Post
    This is someone who opens a poll and then closes it as soon as someone else agrees with them.
