Thread: Best Electric Water Heater???
    Default Best Electric Water Heater???
    With heating oil going higher, I'm looking to put in a hi efic electric water heater and shut the boiler down during the summer.
    Any suggestions on the highest EF units available, Im really looking for something ultra efficient?
    scott
    Feb 2005
    Default Rheem or Brad white....
    get a rheem or brad white and put a water heater blanket
    on the unit.....
    as far as ultimate efficinecey you can also put the water
    heater on a timer to shut down after 10 at night and come on at 6 in the morning..
    STAY AWAY from the WHIRLPOOL..
    http://www.weilhammerplumbing.com/galleryi/
    Default heater
    The only way an electric heater can be made more efficient is to add insulation, but they are already quite well insulated. A timer is useless because overnight the heater will not cool down to the point where it has to reheat the water, and even if it did, you would just have to run it longer to make up for the cooler water once the timer activated the heater.
    DIY Hillbilly Southern Man's Avatar
    Jun 2008
    North Carolina
    Quote Originally Posted by hawkmanz View Post
    With heating oil going higher,....
    I would suggest that you "do the math" on electric vs. fuel oil. When I lived in Upstate NY I got rid of my 40 gallon electric and bought a Bock fuel oil hot water tank. As I recall it was the smallest that they made, 20 gallons, and would make hot water faster than it could be used. Although I had a residential boiler to heat the house it was cheaper than putting in a separate zone for an indirect hot water heater, and was more efficient. All I did for the vent was to Tee it into the existing boiler vent, which went to a masonry chimney. I tee'd into the existing oil line as well. The unit paid for itself in less than 2 years.
