Results 1 to 4 of 4
Thread: either fan or ac unit works
    Default either fan or ac unit works
    I've some threads with some of these problems listed but not like this.
    I turn on the ac, fan on auto. The ac unit runs but no fan. I put the fan to the on position and it runs but the ac turns off. It's one or the other. The air is cold when it get blown in but then warms as the ac turns off. It seem to be the same with the heat. Is a capasitor too weak to jump the whole sysem on?
    Chewey
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    Have you recently changed the thermostat?
    Default ac
    Unless the AC stops immediately, it is harvesting the latent cold air in the unit, and that will get warmer as all the cooling is extracted.
    Computer Programmer Bill Arden's Avatar
    Sep 2006
    MN, USA
    Quote Originally Posted by Chewey View Post
    Is a capacitor too weak to jump the whole system on?
    nope.
    It sounds like the temperature sensor on the indoor unit is not turning on the fan.
    Important note – I don’t know man made laws, just laws of physics
    Disclaimer: I'm a big fan of Darwin awards.
