A more powerful fan will use more kWh. It could also be noisier, but the new model might be quieter.
If it is a variable speed or belt-driven fan you can adjust the speed to will reduce the CFM.
Is the air coming in the soffit vents or going out? Fans are often set up to pull in through the soffit vents and exhaust out the gables or roof.
