Results 1 to 12 of 12
Thread: 1" poly pipe
    DIY Senior Member v1rtu0s1ty's Avatar
    Sep 2006
    Chicago IL
    Default 1" poly pipe
    Hi folks,
    I went to M3nards to look for a black 1" poly pipe. They don't have it. The polypipe I saw at Home Depot was only 1/2". Where can I buy them? And are they expensive?
    Thanks,
    Neil
    Plumber jimbo's Avatar
    The tubing you see at home depot is probably not poly pipe. They sell 2 different things....drip irrigation tubing, which is not suitable for main service, and "funny pipe"....a very heavy wall tubing used for sprinler head installs; also not suitable for main service because it uses only push-in fittings, not clamped fittings.
    Poly pipe is available from a plumbing supply, and probably also an irrigation supply dealer.
    DIY Member msgale's Avatar
    Sep 2006
    Default HD does sell some poly pipe..
    i have seen it there, in lower pressure ratings
    Keep in mind, however there are different wall thcknesses, corrsesponding w different pressure ratings.
    and the thickest wall, highest pressure pipe is not easy to insert fittings into, need a hot water bath first.
    also, there are probably some rules for pressure ratings of pipe to be buried
    Sep 2006
    Chicago IL
    I found 1" poly pipes for $75 at 300 ft. I have not ordered yet. I found it from a guy who does patio installation and landscaping. They also install irrigation.
    Anyways, the head that I would like to use is either RainBird 52SA ord 5505S. Both models use 3/4" NPT or BSP female threaded inlet. So, what do I need to attach the sprinkler head to the 1" poly pipe?
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Quote Originally Posted by v1rtu0s1ty View Post
    You typically connect sprinkler heads to the 1" poly pipe using a tee that has 1" insert connections on the run (straight through the tee) and a 1/2" or 3/4" female pipe thread on the branch (the side of the tee). If you are at the end of the line you use a female elbow.
    You screw a nipple or riser into that branch outlet and connect the sprinkler head.
    I have found that schedule 80 PVC nipples are a lot more rugged and reliable than the risers sold at many stores like HD. You can buy assorted lengths of Schedule 80 nipples from Grainger.
    If you can't find the fittings at HD you can usually get them at a plumbing supply or irrigation place. I get mine from a house that specializes in plastic pipe; Portland Plastic Pipe in Portland, Maine. They don't have a web site. They don't even have email!
    Sep 2006
    Chicago IL
    Ok, now I know how schedule pvc 80 looks like. Most of them are color gray. The schedule 40 are always white.
    Anyways, picture below is a sched 80 pvc nipple. Hopefully, the image I posted is correct.
    I understand the connection from nipple to sprinkler head. However, I'm a bit lost on how I will connect the nipple to the 1" poly pipe since there is no thread on the pipe. What am I missing? Maybe, if you post a picture, I will understand it more clearer. Thanks.
    Sep 2006
    Chicago IL
    Ah, I found a nice picture.
    Check this out. So what is that black piece called that is in between the green riser and the polyethelene pipe?
    Oct 2005
    New Hampshire
    Here is a link that contains some pictures.
    http://www.cornerhardware.com/poly_p...6748_6961_7831
    The part that you want is called an INSERT REDUCING COMBINATION TEE.
    You can get them for 1" pipe where the branch outlet is 1/2", 3/4", or 1" FPT (female pipe thread).
    If it is at the end of the line you can get an elbow that has a threaded side and an INSERT side. It is called a FEMALE ELBOW or just FEMALE EL.
    I have seen them at HD.
    Sep 2006
    Chicago IL
    Quote Originally Posted by Bob NH View Post
    Awesome!!! Those pictures from the link you gave to me really helped a lot. I see tons of them at Nemards. Looks like I also need to buy a tool that will crimp that circle metal.
    Thank you so much!
    Oct 2005
    New Hampshire
    Thank you so much!
    Most use a screw clamp. They don't need a special tool except a screwdriver or nutdriver. It is handy if you have a battery powered drill.
    If the kind that need a tool are much less expensive then you may want to buy the tool.
    Sep 2006
    Chicago IL
    The one I saw(was a video), the guy used a crimping tool. However, I think I will just buy the one which uses screw. That's what I used for my garden hose when I broke the end. It's cheaper too. I should just make sure that I should get stainless steel, something that will not rust.
    Thanks for the idea.
    EDIT:
    This is exactly the same what I used for my garden hose. Hopefully that's what you were referring too.
    Sep 2006
    Chicago IL
    I went to M3nards and saw the parts I need. I was able to find the 3/4" threaded elbows to 1" that will fit the 1" poly pipe, the 3/4" riser, etc. While I was there, I decided to try 1" riser, 1" elbow but I wasted/lost a lot of time and did not have luck finding the parts and volting them together. So for that very short length maybe 12" of 3/4" diameter, will there be a huge impact on the pressure and gpm?
