Oscar Cook
The house is 25 years old, and I moved in 12 years ago. The problem began as a small leak around the metal sleeve, marked “X†in the picture, but only when the water was turned on. Now it’s a gusher. This may only be a washer problem, but I’m not sure how to remove the stem.
I think at one time there was a handle which was fastened on with the screw in the front. It may have broken, in which case the previous owner (who botched everything he did) removed the handle and put the screw back in. It is now corroded in place.
I don’t know if the pipe going in is galvanized or copper. I don’t know if I should try to unscrew anything at that large “nut†on the faucet. I think it is molded to the rest of the faucet. (I know to turn off the water and hold opposite on faucet while unscrewing. Actually, I don’t know WHAT to do).
To turn the water on, you have to turn that round tube with a pair of channel locks and take a bath. Any help, advice, or suggestion is appreciated.
