The tank is leaking air. It could be a bladder leak, or it could be from the valve or a seam. Take some soapy water after you pump it back up again, and see if you see any bubbles around the valve. It might be as simple as thightening the guts of the valve. If it isn't that, then it sounds like you need a new tank. How long is the warranty? My unprofessional opinion.
, pumped it back up to 28psi(should the gauge on the pump be showing this pressure also?)turned pump back on built system pressure to 50psi...all was well for 3days,short cycling again drained tank used tire gauge..no pressure at the shrader valve again
, so I have once again pumped up the bladder , my pressure tank is just under 2 years old
a Well-x-trol WX202Pro....any ideas?
