wp1
- Messages
- 9
- Reaction score
- 0
- Points
- 0
Hi again. I have this question: Can someone recommend a good brand of shallow well pump to me? I am looking for a 3/4 hp.
The reason is that I recently installed a craftsman 3/4 hp shallow well jet pump and I installed a 2 gallon sears captive air tank directly on top of the pump. This set up is a 40 - 60 psi . Everything was working wonderful, but when I came to look at the pump an hour later when it was shut off I noticed water leaking at the bottom where the motor and pump meet. I took it back to sears, got another one and the same thing happened. I decided I bought two lemons and just got a refund. As I think back on it I am wondering if the air tank being directly on top of the pump was pushing so much pressure downwards that it was causing the pump to leak? Maybe I should have place the air tank in another spot? . I can't believe I got two back to back lemons. The pressure on my water tank was 50 psi when I observed the leak. Any help please? I don't want to get a third craftsman pump at this time until I research futher.
Thanks very much.
Well is only used to water my small lawn. Thanks.
Thanks very much.
