Thread: Tracing a 110v outlet circuit fault
    Smile Tracing a 110v outlet circuit fault
    How shall I trace the power to my outlet circuit? (Different circuit, inside & outside outlets only) There is power at the main panel breaker and it appears to look fine, does not trip - but there is no power at the outlets, in or out.
    There are 4-5 outlets, none of them in constant use. Thx!
    Plumber jimbo's Avatar
    Firtst suspicion is that there is a GFI outlet somewhere which has tripped. It is not unusual to find one GFI controlling bathroom + garage outlets. Or kitchen and/or living room + patio.
    Look in the bathrooms, the gargage, and in the kitchen for an outlet with the test/reset buttons on it.
    Default Gfci
    I found one in a bathroom under a bench on one job where the garage food freezer had tripped it and they did not even know it was there. They had resorted to using an extension cord, (after all the food spoiled), because they just assumed the outlet was broken.
