Results 1 to 3 of 3
Thread: Attic Fan Motor
    DIY Member gmrules's Avatar
    Mar 2007
    Raleigh NC
    Default Attic Fan Motor
    decided to just replace the motor
    how hard is it?
    can it be done from the inside?
    where can I get new motor?
    can I go bigger or should I go bigger?
    Motor Says
    DOW-136034 120V 3.4 AMPS
    Thanks all
    Not hard to install, unless trying to do it in the heat of the day. It can be done from the inside. Be sure to remove power before replacing.
    Check out the big box stores, HD and L...s have them look in the construction supply area where the fans are, I would stay with the same size motor.
    Grainger for motors
