OK. Lots of opposing opinions now.
IMO that's because there are a few anti business/salespeople/CSV non well/pump guys here that aren't thinking the problem through.
IF you enlarge the pipe and stop valves you'll get more water outside but, if use water in the house, the pressure will fall throughout the entire system and the sprinklers will use most of the water the pump can deliver while the house will suffer low flow and pressure.
You can't solve this/these problems without a CSV or a constant pressure pump unless you reduce the number of sprinklers and allow the pump to cycle on/off.
So the question you need to answer is what is more important, wearing on the pump with the cycling, not watering as much as you want all at once, or having good flow and pressure in the house when you use water and... when you get all the water to flow outside as you seem to want to, how do you know what effect if any that will have on your well?
If you draw the water down in the well the water quality can be effected, the pump has to pump water from a deeper level and the pressure and flow may decrease, the water may go down to the pump's inlet and allow it to suck air and run dry and ruin the pump while you have no water until you replace the pump, which you may not be able to do and have to hire it done at great expense.
Lush green grass is not that important to me. And in my 65 years, it always led to my having to mow it! And that caused wearing out my mower from the original hand push type (although they were made like a tank and if you didn't let them rust, they probably would last forever) to my late garden tractor. If I ever go back to a house (I live in my motorhome, currently visiting WY) I will spread gravel and paint it green before I'd mow grass. I might have to buy some of that fresh cut grass in a can though.
A CSV shouldn't cost more than $150.
