Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: CPCV Supply And Lamp Heat
    Jack of all trades, Master of none KULTULZ's Avatar
    Nov 2006
    ROCKVILLE, MD
    Post CPCV Supply And Lamp Heat
    Is there a practical guide or code that recommends/states how close CPCV can be placed to recessed lighting? This is in an overhead installation and the lamps will be IC.
    Again, thank you.
    Gary
    Jack of All Trades...
    ...Master of None...
    Plumber jimbo's Avatar
    Check with the pipe manufacturer, or the plastic pipe institute ( plasticpipe.org). I dont know the spec, but would be very leery of putting plastic near a lamp. Naturally, the pipe is rated for domestic hot water ( 140 max) and is OK for use in a hot attic, where the air temp may approach that number. But I would be very careful about what could be much greater heat from that lamp.
    Nov 2005
    Central Florida
    CPVC has a maximum service temperature of 200F. The working pressure must be derated as temperature rises:
    http://www.harvel.com/piping-cpvc-derating.asp
    Its melting point is around 212C (Web searches will turn up numbers from 175F and up). I was surprised to see the variation and lack of definitive information.
    I'd lay a piece of pipe up against the can light for a while and see what happens.
    Nov 2006
    ROCKVILLE, MD
    Thumbs up
    Thanx Guys!
    This is a condo remodel with a fire rated ceiling and has two tiers. Water supply (1/2" CPCV) is routed through the ceiling(s).
    I have found a fire rated sheet metal box to put the lamp into (to preserve fire integrity). I thought that there may have been a code requirement or thumb of rule for proximity.
    Nov 2005
    Central Florida
    I'd be sure to see exactly what they mean by "fire rated". Paper, for example, famously autoignites at 451F, above the melting point of CPVC; the box might get hot enough to melt the CPVC, but not start a fire.
    Nov 2006
    ROCKVILLE, MD
    Post
    Quote Originally Posted by Mikey View Post
    That is what I am afraid of. The surround box guarantees no fire break through for one hour. What concerns me is the proximity of the light housing causing breakdown of the CPCV and subsequent flooding.
    Here is the enclosure(s)- http://www.ezbarrier.net/content/view/12/26/
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Normally non-IC recessed lighting should be kept atleast 3" away from any combustible material. But since you are using an IC rated box, I don't see why you should have any problems if you put a nice barrier of insulation between the IC box and the tubing; that's assuming you would have a gap of atleast 6" between the tubing and IC box. But that's just my opinion as the same practice is done whenever plastic wiring or tubing is ran close to furnace ducting.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Nov 2005
    Central Florida
    Just how close to the housing will the pipe(s) be?
    Default Cpvc
    I would err on the cautious side and not put it near the light, regardless of any minimum dimension. A change in conditions of any kind, such as the pipe being drained while the light is on and you could be looking at a damage liability claim.
    Nov 2006
    ROCKVILLE, MD
    Post
    Quote Originally Posted by Basement_Lurker View Post
    The IC lamp will actually be placed in a sheet metal box (see referring URL above for details) and will not be in open air. I have to re-measure but I believe final installation will be at least six inches and there will be insulation placed between this box and the tubes.
    This ceiling has trusses to hold the upstairs floor and fire rated sheet rock is attached to galv. steel channels to make the lower ceiling. As I understand, IC rated lamps call for a lower wattage bulb and will shut itself off if a pre-determined temperature is reached.
    Let me see how far I can mount the lamp(s) from one truss and I will get back. Would I be better off asking this in the electrical forum or are most of you guys well versed in both (which I would imagine will be the case)?
    Again, thank you.
    Gary
    There are good electricians here. I am anxious to here if the electric code has any specs about where you can put a fixture with respect to a pipe. The standard off the cuff reply would be that tradesmen "have no respect" for the other guys stuff! Plumbers, electricians, and HVAC installers always compete for real estate on new contstruction!
    Default pipe
    The "standard" separation is usually 1", but that does not take into consideration any special requirements for a specific pipe type. Any specific requirements are the responsibility of the installing mechanic. Electricians know wires, not water pipes.
    Nov 2006
    ROCKVILLE, MD
    Post
    I think I have found my answer. The TENMAT protection cover.
    It simply covers the can. That and a respectable distance/insulation should do it I would think. Thoughts?
    Nov 2005
    Central Florida
    I think anything that would provide separation of the light fixture and pipe would be sufficient. The TENMAT cover would do that, and additionally seals up the ceiling penetration in the event of a fire above. Should do the trick. I'll duct-tape a thermometer and a piece of CPVC to one of my IC/AT can lights this weekend and let you know what happens.
    Nov 2006
    ROCKVILLE, MD
    Thumbs up
    Appreciated!
