Results 1 to 5 of 5
Thread: P Trap question
    Default P Trap question
    I am in the process of installing a bar sink outside on my lanai. I hae puntchured the wall for the drain that will connect to my kitchen drain. My question is my drain pipe is higher then my sink drain. Will that cause a draning problem? Thanks for the advcie
    Default drain
    NO way to tell without seeing how you make the connection.
    DIY Senior Member captwally's Avatar
    Apr 2005
    Florida
    Just remember that water seeks it's own level
    Measure Twice, Cut Once
    Wally
    Default Well
    To ask a silly question? My drain pipe (exit) is higher the the bottom of the sink. Will that creat a problem for draining?
    Default drain
    The water in the sink that is higher than the drain will empty normally. But once the level gets even with the drain in the wall it will stop draining and the water level will stay at that point forever.
