Results 1 to 6 of 6
Thread: Condensation on basement pipes
    DIY Member coopns's Avatar
    Sep 2006
    Massachusetts
    Default Condensation on basement pipes
    Just moved in so seeing lots of new situations...
    In basement I saw a few copper pipes that had some condensation...little drips of water coming off them. I had all the windows in the basement closed but did open one window. It was very hot and humid just outside of Boston. Does that sound right? Why were some pipes dripping a bit while others weren't? And should I keep the basement closed and run the humidifier or open all the windows?
    Previous member
    Jul 2005
    Riverview, Fl.
    The reason some were dripping was that water was run through those pipes recently. The cold water is what starts the dripping. You could use Pipe Wrap to insulate them. That would stop the dripping.
    bob...
    Dec 2007
    There are several comments to be made here.
    Water will condense on pipes when the dew point temperature is at or above the temperature of the water in the pipes. Water condensing on some pipes and not others indicates that wate is being used on those lines. The incoming water in those pipes has not warmed to room temperature. Sometimes this can also indicate water leaking such as a running toilet or, leaking faucet. Make sure that you are not wasting water!
    Insulating the pipes can help prevent or, limit condensation.
    Water condensing on pipes is an indicator of very high humidity. I would suggest closing up the basement and running a dehumidifier to prevent mold and mildew.
    Not a Master Plumber novicepiper's Avatar
    Apr 2008
    CAN Toronto GTA
    Default i have the same issue
    So i have the same issues - i just thermal wrapped the outer basement walls and there seems to be condensation on the cold pipes (not insulated)- if i wrap said pipes (cold) & (hot just to help keep the hot water warm)- what are the chances of water gathering within the wraps inner wall and the copper pipes outer wall?
    Is there any danger of:
    corrosion
    mold
    leaks
    thanks in adavance novicepiper
    Dec 2007
    Insulation creates a dead air space. This air will not have the moisture content to condense... The insulation keeps new moisture laden air from reaching the pipe to condense.
    Apr 2008
    CAN Toronto GTA
    thanks as always redwood
