hj and his traditional ways may say you can just solder in another brass trap to the lead. Is your wall fitting tee all lead? If not you can replace the lead with plastic. Eventually all the lead will probably have to be replaced. A temporary repair is to try to cut the brass flat and use a compression coupling.
hj, I have decided that I am not going to try to resolder a twisted delta valve even if it is below your standards.
? A month ago we were Junior Members. Terry promotes fast.
