Results 1 to 8 of 8
Thread: Delta Single Handle Shower Faucet - Leaking Profusely
    Post Delta Single Handle Shower Faucet - Leaking Profusely
    I have an older (8 yrs+?) Delta single handle faucet system that began leaking profusely last evening (wife & I were out & somehow the babysitter & my 2.5 year old managed to do something when having her bath). A large amount of water is coming out from the tub spigot (not shower) when the faucet handle is in the off position.
    When I exert inward & downward pressure on the handle the leak will stop - but when pressure is released it begins again. Any help on starting points, diagnosis / repair approach would be appreciated.
    Basis surfing on this site & Delta's site show I might need to replace the Seats & Springs &/or the Cam & Packing mechanisms. . . are these replacement parts generally available at HD or Lowes? (Assuming I can determine the model)
    Dec 2007
    You need to replace whatever parts your particular model uses. I picture posted would be helpful. Parts are readily available. I would recommend using Delta OEM parts. Some Delta valves can be ruined by improper disassembly.
    Default Delta Single Handle Shower Faucet - Leaking Profusely
    I've been looking on Delta's site to try to locate model # - no luck thus far. Attached is a picture of the fully assembled mechanism - if another view (shower head, etc.) would be helpful please let me know.
    Thanks for your assistance.
    Delta RP3614 kit includes all those parts you mentioned.And best of all,it includes instructions.
    Plumber jimbo's Avatar
    Actually, based on the 8~2 o'clock screw locations, this is not a 600 series ball type shower, which would be 8~4 o'clock. Proably a 1300 series. Best to turn of the water and remove the cartridge to make sure what one you have. Maybe take off the handle and the escutcheon and give us another picture.
    Please be aware that the bonnet nut which secures the cartridge is often stuck, and turning it to hard can cause TERMINAL DAMAGE to the valve body. Be prepared to possibley use a Dremel or hacksaw to slice across the nut. new ones are available. You can try a vinegar soak first, but this is a common issue.
    Dec 2007
    Heed Jimbo's advice!
    The nut is very thin and if you squeeze it with channel locks or a pipe wrench you will flat spot it and make it even harder to remove.
    An application of heat usually works very well.
    The valve is connected to the valve body by 3 small tubes. If you twist too hard these will shear off. When this happens most plumbers would just replace the valve. Hj has been known to repair them, I tried it once on the bench. It was not an easy task!
    Dec 2007
    It should be something similar to the valve linked below. Actual Part numbers will probably be different.
    http://www.deltafaucet.com/media/Pro...14455_c551.pdf
    Thanks for the information & assistance. We've managed to stop the bleeding (or dripping) for the time being - I travel for work but plan to tackle this later in the week when I return home. Thanks again for all the input.
  1. Delta Single Handle Pull-out leaking??
    By jeholman25 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2011, 06:13 PM
  2. single handle delta kitchen faucet
    By higgledy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-26-2011, 06:20 AM
  3. Help - Delta Single Handle kitchen faucet
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2010, 06:40 AM
  4. Delta Single handle kitchen faucet not working
    By hamid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2009, 08:53 PM
  5. Leaking American Standard single handle shower faucet
    By VT Pats Fan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2006, 01:24 PM
