Originally Posted by
acemueller
I have one of those old Custom's too (actually my second). I'm a little confused about the sequence of things. I have 8 zones. I have ony 9 tubes leaving the controller (and a 10th which is capped). All was well for several years. Then zone 7 stuck open a little tiny bit (dribble from heads). I replaced the valve and all was well for a year. Then last week, zone 7 stuck full bore open. I noticed a puddle outside the garage where the 9 tubes leave the garage. One tube seems sheared off. But while I have the end of the tube which ultimately attaches to the controller, I didn't find another end (in the dirt), so I surmized that maybe it is the discharge tube I've seen referenced. I capped it. Capping it keeps anything from turning on. So.... is that in fact the discharge? Is the discharge where pressure goes when the controller enables a zone by relieving pressure on the control tube? With only 9 attached tubes, would I assume that there is no "source" line - just the 8 zone valves picking up their water from the main feed at each valve and routing it through the control tube? This would seem to imply that in myh situation, the controller has completely failed in terms of sealing off zone 7's control tube from the discharge tube. Am I thinking right? Thanks for any insight! Thomas.
