Results 1 to 11 of 11
Thread: Need help with shower valve cartridge replacement. Gerber, Harden Brass, and Matco-No
    DIY Junior Member farmoci's Avatar
    May 2008
    South Carolina
    Default Need help with shower valve cartridge replacement. Gerber, Harden Brass, and Matco-No
    Hi -
    I am trying to replace the shower valve cartridge for my single handle shower faucet. The plastic lip of the valve cartridge is broken . . . unless I turn my handle just right, my shower will leak! My problem in replacing the cartridge is that I don't know who the manufacturer is of my single handle shower faucet. Because I couldn't find a replacement, I actually glued the broken plastic piece back, but that only worked for about a month. Does anyone have any suggestions for tracking down replacement cartridges? The only identifying information on my faucet is "UPC" and "CSA", which I suspect is not unique to this manufacturer. Attached are some pictures . . .
    Dec 2007
    Have a look see here...
    http://www.arpny.com/
    Click on "single lever faucet cartridges"
    You will find it I guarantee it!
    I would have looked it up for you except my PDF reader is acting up tonight and shutting down by internet browser...
    Dec 2007
    Okay I got it to work finally!
    That cartridge was used by Gerber, Harden Brass, and Matco-Norca and is available at the link I posted above.
    May 2008
    South Carolina
    Thank you so much!!!!
    DIY Junior Member aaronrusz's Avatar
    Apr 2011
    Richmond, VA
    BUMP
    I think this is the one I have too. I'm trying to replace the handle and need to either figure out how to remove the whole valve assy and replace it, extend the shaft on the cartridge to 3" to accommodate the new handle assy, or replace the cartridge with one that has a long enough shaft. Please help.Name:  photo.jpg
    Plumber jimbo's Avatar
    UPC is NOT a brand name. It is the "code" seal of approval granted by IAPMO ( International Association of Plumbing and Mechanical Officials). UPC stand for Universal Plumbing Code. Most jurisdicitions require all plumbing materials to be approved by a recognized approval body, like UL for electric). IAPMO is a universally accepted approving agency.
    And it seems this post is in the wrong thread. I can't seem to find where you started this discussion.
    DIY Junior Member aaaaathatsfiveas's Avatar
    Sep 2013
    New Mexico
    Thumbs up Thanks!!
    Quote Originally Posted by Redwood View Post
    This thread totally saved us today. Amazing that 5 years later this is still good information. Thanks!!
    -A
    The manufacturer is always where I go first, as long as the customer can wait for it to be delivered.
    DIY Junior Member robert13084's Avatar
    Nov 2013
    waco, TX
    I have both the cartridge and the pressure balancing part in stock!
    DIY Junior Member joe979xx's Avatar
    Jul 2013
    nyc
    I found at New York Replacement Parts - Plumbing and Heating Supplies.
    NYRCORP . com - Part# GERBER Single Lever Cartridge - 95-154 CARTRIDGE
    DIY Junior Member trentenmarschel's Avatar
    Nov 2013
    union star, WI
    hey i just found my shower leaks quite a bit and was looking around on where to buy the cartridge. http://www.nyrpcorp.com/gerber-singl...rtridge-95-154
  1. Shower cartridge replacement help
    By HudsonRiverBlues in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2013, 03:32 PM
  2. Help with shower valve cartridge replacement
    By jleecong in forum Shower & bathtub Forum & Blog
    Last Post: 04-30-2013, 01:27 PM
  3. Need help with shower valve cartridge replacement
    By ameneses54 in forum Shower & bathtub Forum & Blog
    Last Post: 02-27-2013, 06:14 AM
  4. Harden Temptrol shower valves
    By M Q in forum Shower & bathtub Forum & Blog
    Last Post: 02-17-2006, 09:45 AM
  5. shower valve cartridge replacement
    By PaulH in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2005, 07:40 AM
