Results 1 to 6 of 6
Thread: Toto drake fill valve issue
    Default Toto drake fill valve issue
    when the toilet is flushed it hesitates for several seconds befor filling. It seems to be getting worse as far as how long it hesitates. There do not seem to be any moving parts of the fill valve that could be sticking. It is a Toto gmax part. Any ideas? Thanks. Rick
    http://www.terrylove.com/korky/
    It may need a replacement cap made by Korky. You can find them next to the QuietFill Valve by Korky in the plumbing Isle of Lowes.
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    I had the exact same symptoms. The replacement cap Terry mentioned solved the problem. I talked to Korky's customer service. They walked me through the troubleshooting procedure, and since the toilet was less than five years old, sent me a free replacement cap.
    Default Gmax malfunction
    Gmax on Drake is causing a water hammer like noise as it fills the tank. Running the cold water in the sink stops the noise. Seems like there may be dirt in the GMAX. Any instruction on how to take it apart and clean out the GMAX?
    Dec 2007
    The cap just unsnaps.
    If it is a jackhammer type noise it may be a loose washer on the angle stop valve coming out of the wall to the toilet.
    Open up the fill valve at the wall all the way
    I closed the valve and then re-opened it. The noise is gone. Thank you
