Results 1 to 5 of 5
Thread: White Rodgers 13a02-102
Hybrid View
    Default White Rodgers 13a02-102
    Hey guys, quick question. is there a replacement for the 13a02-102 zone valve that i can use and keep the old body in? or do I need to cut the old valve out and replace it with a newer style? I see its been replaved by the 13s16-102. does that use the same body?
    White rogers lists your model is obsolete. Here is the details on the replacement they suggest:
    http://www.white-rodgers.com/wrdhom/..._06_pg0135.pdf
    Thanks jimbo, I found that. What I was just wondering was if they changed the style of the body on that newer zone valve. I am just wondering if the next bad zone valve will require me to have to cut out the whole body next time becuase i used the last 13a02-102 I had. I can't seem to find a picture online of just the brass body.
    Sorry, I knew that your real question was can you replace the actuator, and I do not know. I think W/R has a number or email addr. on the website that you can contact.
