Trying to balance flow to several radiators is almost impossible unless you use fittings such as MonoFlo tees which divert some of the water to the radiator and then mix the return water before it flows to the next one, and so on. You cannot do it with conventional PEX, or any other, fittings, unless you use a two pipe system and engineer the pipe sizes to create the necessary pressure imbalances.
