Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Post your Pics, We would love to see your projects!
  1. #16
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    Smart folks learn to rotate the ball valve just a bit, and look for any bubbles coming up ...
    I did just that with a full bowl of water during shakedown ...
    No bubbles!
  2. #17
    Nov 2005
    Central Florida
    Default A question for garyl53
    I like the little corner shelf in your shower. Did you consider a niche shelf arrangement, and if so how did you convince She Who Must Be Obeyed that the corner shelf was OK?
  3. #18
    DIY Junior Member eeka's Avatar
    Mar 2008
    Massachusetts
    Before:
    After:
    Photos don't quite do it justice, but the entire bathroom was previously covered in godawful off-white tile with awful borders, most of which was installed crookedly. And which I discovered seemed to have been installed using drastically different grades of adhesive, and installed over wallpaper attached to normal non-blue sheetrock. Underneath all this was plaster and lath and original wood wainscotting, but it was unfortunately way beyond restoring, so it's now inside my walls. The godawful tile is all either demolished or walled over, depending what was practical. Well, except for the godawful tile around the tub because, um, couldn't really get rid of that without replacing it.
    My next plan is to replace the tub with a deeper one with jets and replace the last of the godawful tile with mosaic tile.
