RochNY
- Messages
- 28
- Reaction score
- 0
- Points
- 0
I noticed a small (2 inch long) crack(s) above the neoprene sleeve where they hooked pvc drain pipe to the existing cast iron pipe from the toilet above it. I think the crack(s) is from the snap cutters used to cut the old cast iron pipe out. Is this common when using a snap cutter? It is not leaking and is about a 1/32 inch wide. Is this something that should be fixed? Thanks.
