We recently purchased a camp and were unable to do a well test as the outside well (driven point) was in a small shed under 5 feet of snow. Once the snow thawed we were able to see that the pump had cracked off of the
water tank. Today our plumber brought a new pump and tank into the basement and they could get the system up and running but after several hours of work they weren't able to maintain water pressure- with the water running - there seems to be an air leak.
He thinks that either:
1)There is a crack in the underground line to the house. He noted that the 1 inch pipe inside becomes a 3/4 inch pipe in the well house - there may be a leak in the reducing fitting that is underground.
2) There may be a crack in the well casing itself. There is nothing visible nor could they hear any air leaks or air getting sucked in. The system holds water but they are going to go back tomorrow to check to see if the pipe is holding water.
Does anybody have any suggestions or ideas?? Just hoping that this isn't the start of money pit problems!
thanks,
Pam
thanks,
Pam
