Normally, we would recommend that once you put water on that joint the first time, then the only proper repair is to take it completely apart.
Given how hard this job was, and it it is in a spot that won't flood grandma's bedroom if it leaks, I would be inclined to leave it, but keep a close eye on it.
I am sure some guys will recommend having a plumber come in and redo the whole thing. That would certainly be the "best" thing to do. Sometimes in life, you take a deep breath and put you money down on 00 hope for the best. Everything is a crap shoot!
I turned the water on and psssssssss out came the water out of a couple of small holes or voids that didn't take. In my horror I immediatly shut the valve off of the water line and preceded to reflux the joint and heated up the elbow till it started to turn the flame a greenish tint. Then I melted more soder around the joint and wiped it clean.
This morning still no leaks. My question is. Is what I did ok?? Will I have problems down the road??
