Thank you in advance for any help you throw my way. I have been reading a lot and there are some great members on this forum. This is the first property I have owned that had a well on it so please forgive my ignorance.
Here is my issue: We started noticing an irregular water pressure for the past 2 days. I just walked out to the pump house (I left the bthrm sink running) and could hear the pump clicking on and off in there. I noticed the pressure valve would hit 30 psi, pump panel would click, pressure rose to 60 psi and then immediately began dropping to 30 psi. So I had a pump turning on and off, on and off. Before I call a repairman out, does anyone have any advise as to what is going on, why it is happening and is there a DYI fix here. If at least, I hope to get a little educated so I am not at the mercy of the repairman. The pump is a Goulds if that helps.
