Hi all -
I had a plumber over yesterday to install a new Toto Drake (bathroom remodel). It turns out that the toilet flange (the plastic part) was just a bit too high so the toilet sits on the flange itself and the toilet sits maybe 1/8" off of the floor.
The toilet flange is installed in a concrete slab, so I can't adjust the height. The plumber told me I should just try a different model toilet, maybe other models have just a little more clearance. Is there much variation between toilet models? I am thinking of trying some different Toto models or maybe a Kohler Cimarron because I can just get it from HD and return it without any hassle if it doesn't work.
Otherwise, he said, I could put the toilet on shims or some other hacked up solution, but I would prefer not to go down that route. FWIW, the tile is laid directly on the concrete slab as before, and the new tile is thicker than the old tile. I guess the old toilet had a lot more clearance underneath than the Drake.
(I know there was another similar post recently on this subject, but I thought I'd post since I have different circumstances.)
