Thread: Converting normal water supply to tankless toilet
    Default Converting normal water supply to tankless toilet
    Hi all,
    Is it easy to convert a normal water supply line to a pressure assist tankless toilet? How do you do it? Will it have enough pressure to flush?
    Phil
    If you plan on using a Flushometer style, you will need a 1" line to the toilet. The rest of the house will need to be up sized too.
    The reason a 1/2" line works for a tank style toilet is the water stored and ready to drop in the tank.
    Thanks Terry!
    I will check to see if there is a 1 " supply line - it is in a business.
    Phil
