Results 1 to 15 of 15
Thread: fluorescent light bulb's don't work with Timer's?
    DoD Army bjferri's Avatar
    Jun 2007
    Maryland
    Default fluorescent light bulb's don't work with Timer's?
    Why is it when I put a fluorescent bulb in a light that is on a timer it starts to blink, even though the timer os off? I have lots of timers around my house instead of the regular switches...does this mean I cannot use this type of bulb?
    Brian
    Central Florida
    I don't see any reason why this should happen, if everything is properly wired. A switch is a switch. Are these timers mechanical or solid-state?
    Jun 2007
    Maryland
    The timers are solid state. I don't understand this. Not that I'm an electrician, I don't think I wired them incorrectly.
    Brian
    Plumber jimbo's Avatar
    Lighting control devices....timers, photocells, and motion sensors.....can be problematic with fluorescent. Especially electronic devices like your timer.
    Here is the reason......
    Simple electronic in-line devices like maybe your timer are designed to replace a simple on/off switch in a box where only the HOT wire is present, not a ground or neutral. Therefore, they way they work is to "steal" a tiny amount of current. That is when the timer or photocell wants the lights to be OFF it is still passing just a few milliamps of current to operate its circuits, and be ready to switch when the time arrives. For incandescent bulbs, this current just passes through the bulb, and is so small that it does not even cause a little glow. But, flourescent bulbs DO NOT LIKE this set-up. It will cause the flickering etc. that you are seeing.
    The only solution is to get a timer which is specifically rated for fluorescent. They are much more expensive, and often require a neutral and/ or a ground to be present in the switch box, and you may or may not have that.
    Also, you have to look specifically at what kind of lamps/ballasts you have. Some of the timer/photo/motion devices will be rated for MAGNETIC ballast only, some for ELECTRONIC only, and some for BOTH. For a look at some devices and specs, try www.wattstopper.com
    Default timer
    Many nonmechanical timers are labled specifically that they are not suitable for devices with ballasts.
    Jun 2007
    Maryland
    I got it! Thanks. I do have the 3-wires needed; however, these timers are new and were expensive (maybe $15 or so) so I'll hold off. Thanks again!!
    Brian
    Quote Originally Posted by bjferri View Post
    Unfortunately, @ $15, these fall in to the category of "cheapies". Think $35 to $55 for what you need.
    They somehow need the closed circuit provided by the incandescant filiment to operate.
    2 wire photo cells are the same way.
    Jul 2007
    USA
    I hate to be a kill-joy but I have the same problem with light switches with LED lights in them (to find them in the dark) and I have found that some brands of CFLs do work and do not flicker.
    It's trial and error, but I have had lots of success with the Lights of America brand.
    Another trick, is that if you have a device that uses more than one bulb, a chandalier for example, you can use CFLs + one ordinary incandescent. The presence of the single incandescent will stop any flickering.
    CFL could use an electronic ballast or a magnetic one...my guess is a magnetic one might be more likely to work.
    Feb 2005
    Omaha, NE
    Intermatic makes a switch capable of use with fluorescent bulbs - EI600. If it's like the model it supersedes, which I have in my house, it has a little motor which mechanically moves a SPST load switch. Mine has a AAA battery which needs to be replaced about once a year, since it operates the switching motor.
    Sep 2006
    MN, USA
    My X-10 light switches have "latching" relays and work fine.
    My earlier research showed that most inline dimmers and photo cells would slowly charge the 200 volt DC capacitor until the "start up" circuit starts. The bulb would then flash as the switching power supply drained the main capacitor.
    The old style (plug in bulb) CF lights are also ok, but are less efficient.
    motor driven timers are also fine with CF lights.
    Jul 2007
    USA
    Interesting. What do you mean by "old style plug-in bulb"?
    Are those like the circular CFLs that have four prongs that plug into a plug on the light?
    Like this:
    or
    perhaps these:
    Sep 2006
    MN, USA
    Quote Originally Posted by Ian Gills View Post
    Actually both of those since they tend to use magnetic ballasts and a starter.
    Although I've now seen both with electronic ballasts.
    Circline bulbs are usually magnetic ballasts. The plug in bulbs...if they have 2 pins that is usually a magnetic ballast, and if they have 4 pins, that is electronic ballast.
