Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: table saw question
  1. #16
    I do dig those rearmounted motors. They allow a dual bevel too.
    You should check out the Makita 12"SCMS. The most recent issue of Fine Wood Working did a comparison of 12" sliders and this one rated highest (the Bosch was a close second).
    The past 3-4 years, the Mak and the Bosch have run neck and neck in the SCMS category.
    Either co makes fantastic products.
    (important note: I'm not a pro)
  2. #17
    DIY Junior Member Marv's Avatar
    May 2008
    Northern Illinois
    I have a left index finger which points just a little east of straight ahead! And that was done with a hand saw! Just think what I could do with a power saw!
    I bought a new hand saw a couple of years ago. Small blade and extremely sharp. While building a Habitat house, I cut myself about 4 times with it. Very embarrasing!
  3. #18
    May 2008
    Northern Illinois
    Quote Originally Posted by Mikey View Post
    Yeah, but how about a compound miter for an outside corner on a 16' length of crown molding?
    In Fine Homebuilding, I saw a guy make his own wood miter box to hold 14" crown and then cut it with a hand saw.
  4. #19
    Nov 2005
    Central Florida
    Default The ultimate safe table saw
    I still don't believe this:
    http://www.sawstop.com/
    Watch the "Hot Dog" video first... then the "Why SawStop" for some amazing statistics.
  5. #20
    It works, I've seen it at a trade show. They tried to sell it to saw manufacturers. I think they eventually ended up building their own with it in it. There was an article in Popular Science years ago.
  6. #21
    Nov 2005
    Central Florida
    You're right - they build the entire saw, and claim it's the best saw out there, even not considering the safety of it. From what I've seen, I believe them. It's pretty pricey, but if you run a cabinet shop, it doesn't take too many 6-figure lawsuits to justify $3K for a top-notch saw.
  7. #22
    May 2008
    Northern Illinois
    I'll bet they didn't demonstrate it very often. It is a big job and big bucks to replace the locking mechanism after it kicks in.
  8. #23
    I didn't think the locking mechanism needs replacement. The blade certainly does, though.
    They just came out with an 'economy' contractor saw for the bargain price of $1800!!! They're also working on bandsaw and chopsaw.
    A lot of tablesaw haters also like the Eurekazone system (www.eurekazone.com) . It's basically a system of rails and guides that converts your circular saw to a tablesaw/radial/panel saw replacement. By keeping the wood stationary and moving the blade (facing down) the cuts are safer.
    The system works well for the space-constrained. Highly portable.
  9. #24
    Nov 2005
    Central Florida
    Quote Originally Posted by Marv View Post
    Not so. $69 for the new "cartridge", which is the brake assembly, and it's a 2-minute job to replace it. I'm not even sure you'd have to replace the blade, although they say you do.
  10. #25
    Hmm, $70, a new blade, and the time to replace everything is worth me keeping my fingers.
