Results 1 to 2 of 2
Thread: basic tub question, but big help for me!
    DIY Junior Member
    Mar 2005
    Raleigh, NC
    Default basic tub question, but big help for me!
    I just installed a jacuzzi-style fiberglass tub. I am having a leak at the main drain coming out of the tub. Using a brass type drain and overflow parts, there is a rubber gasket at the tub/drain interface.
    Is it OK to use plumber's putty on either side of the gasket? I question, because of the vibration from the jacuzzi, concerned it might need a better solution.
    >>Brian<<
    Try some plumbers putty under the rim of the drain when you reinstall it. That and the gasket on the bottom should fix it. My unprofessional opinion.
