Results 1 to 15 of 15
Thread: Gwyneth toilet
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    Default Gwyneth toilet
    Toto MS60114CEFG Gwyneth
    I see that Toto has two new one-piece Gwyneth models that have the double-cyclone system at 1.28 gallons but without the Unifit of the more expensive Soiree and Guinevere. One with Sanagloss and one without. Looks like a good deal to me. Terry, what would be the prices?
    http://www.easycarts.net/ecarts/terr...l#MS604114CEFG
    SamC,
    I brought in ten of them in Cotton White. 5/27/2008
    The Sanagloss version in Cotton White will be $474.99
    This sure looks like it has a ton of features that people have been asking for.
    Universal Bowl Height, 16-1/8"
    Elongated
    Sanagloss
    Double Cyclone
    Eco 1.28 gallon flush, so you can get your local water rebate.
    http://www.totousa.com/admin/upload/...4cefg-0408.pdf
    WaterSense Toilets for Los Angeles and the Seattle Area
    DIY Member tototalitarian's Avatar
    Feb 2008
    California
    Default This is very disapointing
    I thought you were showing pictures of Gwyneth Paltrow.
    Not even close !
    DIY Member loke's Avatar
    Mar 2008
    Saskatchewan, Canada
    Default MaP data for Gwyneth toilet
    A January 14, 2008, MaP test report that I found online lists the Gwyneth's rating at 500 - the same as the EcoUltramax. The report doesn't show this newer toilet as a "Watersense" one (but does show it as a HET) so I'm guessing that the approval for the designation had not been received at the time the report was printed.
    Sounds to me like a good alternative to the EcoUltramax - better bowl wash, Sanagloss and little difference in price. My local dealer has just ordered 10, as has Terry. Am wondering whether to take a chance and go for the new model without any usage feedback available. Should I trust Toto's reputation?
    A couple of things I noted on the spec sheet to which Terry gave a link - there is no extra little float on the flush assembly on the Gwyneth as in the EcoUltramax and the curving waste channel has the bottom part more exposed than on the EcoUltramax (or EcoDrake, etc.). Not sure about the significance of the latter. Anyone know?
    I'm sure the Gwyneth will have the float that we see on the EcoDrake.
    On the pdf, that's the same picture of the flushvalves they have been using for years. They just need to add a new picture.
    I've been using the Eco Drake, rated much the same as the Gwyneth, seems to work well.
    Adding the Sanagloss and the Double Cyclone rinse will be nice.
    I don't expect the quality will have changed.
    Mar 2008
    Decided to go for the Gwyneth. To my pleasant surprise, the price was lower than the EcoUltramax (though substantially more than your price, Terry!). Was told that Toto appears to be giving some sort of introductory special price. The retailer already had pre-ordered the new model so now we just wait - 8 to 10 weeks - until our city of 200 000 has enough Toto products ordered to fill a delivery truck! The retailer has been dealing with Toto for 12 years so has some track record with them.
    I was advised that one shouldn't put a lot of stock in the MaP testing results for any toilets. He says that Toto designed the original testing but that it has been modified by the company (Veritec) that decided such testing would be good to do to compare toilets and that the new testing isn't particularly meaningful. He claims that Toto only has its newer models tested so as not to be conspicuously absent from the list - but that they do their own toilet performance testing.
    I don't think much about the Veritec testing either.
    I had the Toto Ultimate installed for two years, rated 325 grams by Veritec. We would have 35-40 over all the time, and up to 200 for a big party. It worked so well, that I never bothered keeping a plunger around.
    I've also seen some brands that they tested higher, that were quite easy to plug.
    I was wondering about the pricing on the Gwyneth too, it seems low.
    Feb 2008
    California
    Default Thanks Terry for the help with the visuals on Gwyneth
    Much better than some of the other pix posted here.
    Have a good weekend
    The new Toto Gwyneth toilets came in for the Seattle area.
    I have them in Cotton White for $474.99
    Apr 2007
    Georgia
    Terry,
    Will you be checking one of these out yourself, and giving us your feedback?
    We were talking about which bathroom to try it in at lunch.
    Oh Yeah!
    Apr 2007
    Ontario, Canada
    It does not have the float on top of the flapper like the E-max toilets.
    Not sure how they flush 1.28 it must have something to do with the Double Cyclon design.
    Mar 2008
    Default Gwyneth toilets installed
    Just had two Gwyneth toilets installed in my home this afternoon. Plumber had no problems. Am already appreciating the Universal bowl height. The water spot seems as big as in the old American Standard 13 liter toilets they replaced but the flushing is so quick in comparison (of course, given that only 4.8 liters of water are used!). Like the Double Cyclone - more like the old toilet in action with the swirling. So far I'm happy - and even the odd shaped seat doesn't seem so odd in actual use (as opposed to sitting on the seat, fully clothed, in the plumbing showroom!)
    I have no previous experience with low-flow toilets so would be interested in feedback from others who try the Gwyneth who have used other Toto toilets. Still have 1 toilet left in the house to replace! The space there could accommodate an Eco-Drake (which is much less expensive), but perhaps the Double Cyclone rinse is worth the extra(?).
    Default Gwyneth.... how do you like it?
    Terry, earlier in this thread you said you would be trying the Gwyneth toilet and posting some feedback. That was a while ago. I'm trying to decide between that and an Ultramax - Have you had a chance to get one installed and tested yet? I'm very interested in your impressions and any comparison between the two. Thanks much.
    The Ultramax and Gwyneth seem pretty similar at this point.
    You can get the 1.28 gallon flush in both.
