255' well, water at 45 ft.
Just put in a new pump and motor: 1hp Grundfos 10S10-15 and 1hp 3W 1P Franklin 230V motor. 44gal tank @38psi and CSV1Z. Switch 40-60. Set up was for a sprinker system mainly.
I needed it to push my three Rainbird 3gpm(approx? is that right for this type of head??) Maxipaw impact/rotor type heads, 3 heads/station, 6 stations. So my requirement would be roughly 9gpm? 6 Stations usually run for 20min ea., so 2hrs total watering time.
The first 20-30min it runs fine, 40-50psi and pushes the heads. (By the way the CSV1Z only really holds at 50psi when I'm at less than 5gpm. That's frustrating! I thought it would hold 50psi at 10gpm? Why doesn't it regulate it at max flow? I even have it cranked way down) After 45 minutes of constant watering the pump struggles to keep up and slowly drops just below 40psi. The pressure gauge then takes a quick nose dive and will suddenly drop down to 10-15psi and hold for a few minutes. Then it will surge and go back up to 40 psi for a 15 seconds and after a 10 or so seconds it will drop back to 10-15. If I close a valve and restrict the flow the pump will begin to catch up and return back to 40-50psi and not have irratic pressure issues at all while doing so.
But when I open the valve up again to wide open the same thing happens. I'm not getting any air so I don't think it is running dry. I can't believe that would happen if my water is at 45' and well is 255' deep?
1. Is my pump the right pump for the job? The well guy said it was, but he just stood there 10 min and said, "look it pushes your heads nicely at 50 psi ", but didn't see what they do after 45min.
2. Am I asking too much in running it for 2 hrs at 40-50psi? (Course, it won't do that even if I wanted it to right now)
3. Should I really be trying 10min/6 stations for a total of 1hr. and just do that twice a day if I want to water 2hrs?
4. Am I running out of water? Again, I can't believe that would happen if my water is at 45' and well is 255' deep?
Any clues would be greatly appreciated!
