I want to add a ceiling vent to the bathroom. We currently have a washer/dryer setup in the same room just divided by articulating doors. The window that the the dryer vents thru is glass block and to try to avoid tearing that up, is there some way I can tie a bathroom fan vent line into the dryer vent line? I was looking for some type of a check valve or something that would keep the dryer exhaust from going to the fan and untimately into the room. I had figured on using a y instead of a t to help the exhaust head toward the window instead of the new ceiling fan. The next closest window is about 20 feet away and on the other side of a wall plus this is a basement bathroom so the kitchen is directly above so there is not an option to vent up thru the roof as a direct line.
If It seems possible, what suggestions should I keep in mind>
Thanks.
Chris
Thanks.
Chris
