Results 1 to 5 of 5
Thread: Trouble with pressure balancing valve
    Default Trouble with pressure balancing valve
    Just bought a house that had been "winterized" for about 8 months. After de-winterizing all was well EXCEPT I get ZERO hot water flow from one of the Delta pressure-balancing tub/shower valves. It's about 15 or so years old. Any advice on where to star looking for the problem??
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    Your balancing spool may be stuck. It shood be located behind the face plate of the faucet. It looks like a 1" diameter slotted screw.
    Default Thanks Crow
    Let's say I find it and assume that it's stuck. Now what? Hammer, screwdriver, wd-40? How do I unstick it?
    Feb 2008
    Ontario, Canada
    1)You can try tapping on the large screw (Sometimes it will unstick).
    2)You can shut off your water and try to unscrew that large screw. Once its out
    ------a) Try tapping the entire spool on something hard and see if it loosens
    ------- b ) purchase an identical balancing spool and replace it
    ---------------- i) maybe HD
    -------------- ii) plumbing supply house
    ---------------iii) call delta for replacement part
    Default Thanks, again, Krow!
    Will do! I was kidding about the hammer! Guess I might use it after all. I appreciate the tips.
