Results 1 to 3 of 3
Thread: Sprinkler pump
Hybrid View
    DIY Junior Member mcgyver's Avatar
    Mar 2008
    British Columbia
    Default Sprinkler pump
    I have a shallow well for irrigation (water at 18.5'). Would a 1 hp wayne Sprinkler pump work for me or am i better off with a shallow well jet pump. I've read about issues with the sprinkler pump not being able to draw enough. thanks
    Yakima WA
    I'm not a pump expert by any means, but I believe you must determine how many gpm of water you need to operate the sprinklers then get a pump that will supply that much, probably with a little extra just to be sure. Sprinkler head wear and get a larger diameter thereby putting out more gpm than originally rated, you may add to the zones, and it's nice to have a reserve so you're not always maxed out. Something like have a little more HP in you car than you really need. Some of the pump experts might have some additional thoughts.
    Mar 2008
    British Columbia
    Thanks Gary, my needs are max 7 GPM. most zones are 5-6 GPM. I'm more concerned about the "sprinkler" pump vs a shallow well jet pump. Ideally i need a 3/4hp pump but 1hp would do and i have access to one for a decent price. If anyone knows of a 3/4hp shallow well jet pump used or whatever for a good price PM me. thanks
