Results 1 to 7 of 7
Thread: GFI in series?
    Default GFI in series?
    Hello All,
    If I have four standard outlets in series in my kitchen along the counter top and wanted to convert them to GFI, can I replace the first outlet in the series with a GFI and will that cover all of the down stream outlets?
    Yes, if wired per the instruction with the GFCI.
    Almost all (but not every one) gfci outlets let you daisy chain additional outlets to protect them. If the gfci has connections for both load and line, anything connected to the load side is protected as well as the gfci itself (of course!).
    DIY Junior Member Marv's Avatar
    May 2008
    Northern Illinois
    You really need to know what is all the way down the line. Hopefully your refrigerator is not on the line and kicks the breaker when you're not around.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by Marv View Post
    If it does, its a good warning sign your fridge is failing.
    May 2008
    Northern Illinois
    I have a 1 year old fridge at the office (full size) that just started to trip the GFCI its plugged into. I think its just because the motor is drawing a little extra current as it ages. I plugged it into another outlet and its fine. Motors can often trip a GFCI.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    When they start leaking current. Just because it works in a nongfci outlet, does not mean it is not leaking current. It has been years since I have seen a false trip on a gfci.
    Yes I am A Pirate-Jimmy Buffett
