Here is what I have going on....I am putting a hose bib on a basement wall, outside, on a walk out basement wall that is only 5.5 inches thick inside dimensions.
So I am not using a freeze proof faucet/hose bib. (I do have a shutoff in the basement with easy access to drain the line for winter.)
So...because the wall is finished and insulated on the inside and vinyl sided outside I put a 3/4 copper to 3/4 pipe fitting on the outside and found a nice looking ball valve, 1/4 turn faucet with 3/4 pipe fittings to mount to the copper fitting....with me so far....
I already have this all in place and since the wall is finished I wanted to use a faucet I could remove with wrenches and not solder or un solder something that I can not see in the wall....it goes from faucet to pipe fitting to a 4" long 3/4 line to 90 then up the wall ...I dont want to be soldering on something from the outside and risk a leak on the inside of the finished wall/area...
How do I get the faucet/hosebib to get tight, not leak AND be pointed straight down?
Was I supposed to tighten the faucet and THEN solder the last fitting so the orientation is correct?
Can I use a LOT of teflon tape to fill the void and get it the correct orientation?
thanks Kevin
thanks Kevin
