Results 1 to 10 of 10
Thread: My Pex install
    DIY Member cybervex's Avatar
    Feb 2008
    Southfield, MI
    Default My Pex install
    How is this for a nice clean PEX install? Not quite complete, but getting there. The home build is taking forever as I am the the homeowner, builder, and all the tradesmen.
    ________________________________
    Jay
    Plumber gear junkie's Avatar
    Feb 2008
    Virginia Beach, IPC country
    Looks very nice. Is that a tankless water heater above the manifold?
    Very neat. Good job with the pex elbows.
    Feb 2008
    Southfield, MI
    Quote Originally Posted by gear junkie View Post
    Yes. It is a Takagi TK-3.
    I will post more pics as I finish the install. Its hard to get pics of the full utility closet as it is in a hallway.
    Jay
    Jay, very nice job.
    Where are you putting the water treatment; like at least a water softener? Especially when you have a tankless water heater.
    Feb 2008
    Southfield, MI
    Jay, very nice job.
    Do I need water treatment for city water? I am going to put a filter in the kitchen for the water/icemaker and maybe something at the sink. In my current home, which happens to be on the same block, we have no water treatment.
    Jay
    Feb 2008
    Southfield, MI
    Thanks for the compliments so far!
    Not to bad for an IT Systems Administrator, if I do say so myself.
    Jay
    DIY Member Squ1rrel's Avatar
    Dec 2007
    Texas
    I am sure Gary will say to test the water first....But you may want that softener if you use a tankless, just to be sure...they have a nasty habit of clogging with whatever minerals may be in the water, reducing efficiency and pressure.
    Feb 2008
    Southfield, MI
    Quote Originally Posted by Squ1rrel View Post
    I did buy the isolation valves so that I will be able to clean it as needed.
    Jay
    Find the water company's web site and then their Water Quality Report and then hardness or total hardness. If they don't list hardness call them. Use the maximum figure and divide it by 17.1 to convert ppm or mg/l to gpg. If there is more than 3-4 gpg of hardness your tankless water heater warranty may be voided or not but, it won't work well for very long due to hardness scale build up. It is a very rare city water system that doesn't have enough hardness to justify a softener; that is more than 3-4 gpg of hardness. And there is no filter that will remove hardness and you don't need a filter if your water is always clear. There is no sense in filtering visibly clear water, is there?
    I sell softeners all over the US and find hardness in the mid 20 gpg frequently with some in the high 30s or higher in certain places.
    I have installed many softeners etc. in confined spaces and can tell you that you will have a tough time getting one to fit that small hall closet. So think on installing on the main before the manifold somewhere else. Like in the garage or outside if your area doesn't have hard freezing weather.
    BTW, to clean a tankless takes acid IF the coil is metal it can be damaged with only a few cleanings. It is not much fun and can be needed very frequently if the water is hard.
